injector question
Old Nov 20, 2005 | 10:41 AM
16vzetec's Avatar
16vzetec
Default injector question
does anyone know about injectors??
reason being im building a zetec and its got 90 spec xr3i management at the mo.
i currently have zetec injectors but i also have st170 inlet with the injectors and want to run that instead.
so basically does anyone know if it will be ok and will it fuel right??
Old Nov 20, 2005 | 10:07 PM
sailorbob's Avatar
sailorbob
The quick answer is no, the fueling will be wrong. The eec-iv management is programmed with the size of the injectors and unless you chip the ecu to let it know about the change of injectors the fuelling will be wrong.
Old Nov 21, 2005 | 09:04 AM
16vzetec's Avatar
16vzetec
i will be getting the ecu remapped with a unichip but what i was wondering is are they different ohmage or something?
i dont wanna burn something out
Old Nov 21, 2005 | 09:22 AM
sailorbob's Avatar
sailorbob
I expect they will be about the same but couldn't say for sure. Best to do a quick check with an ohm meter.
Old Nov 23, 2005 | 01:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
best to go after market management and get rid of the MAF sensor, then you can use cossie injectors and a vauxhall fuel rail
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
