misfire on 2wd saph
Old Nov 24, 2003 | 06:15 PM
steveRS's Avatar
steveRS
Default misfire on 2wd saph
Right chaps
Ive changed the plugs, tried differnt gap settings etc (seemed to run its best gapped at 28 thou}
changed the phase sensor and gapped it to 0.3mm
changed the ignition amplifier
changed the crank sensor gapped it at 20 thou
changed the rotor arm and cap
the things left to do in my mind are new leads ( 90 quid is a lot of money if this is not the prob}
also air filter is normal paper type looks dirty and i understand that poor engine breathing = poor running
if anyone else could comment or agree or disagree with settings it would be of great help
regards
steveRS
Old Nov 26, 2003 | 03:27 AM
XR4Timan's Avatar
XR4Timan
Hmmm...how do u gap the crank sensor??
Old Nov 26, 2003 | 01:58 PM
swerv's Avatar
swerv
so when does it miss , at high revs?? under load??
Old Nov 26, 2003 | 04:49 PM
steveRS's Avatar
steveRS
low revs under load
to gap crank sensor to 10mm nuts and set to 0.8mm
steve
Old Nov 29, 2003 | 02:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
steveRS,
steveRS,
The last answer was good... so what was the first one about? I ask as this may causes a miss
Old Nov 29, 2003 | 02:14 PM
Toe Knee's Avatar
Toe Knee
Never knew u had 2 gap the crank sensor
Old Nov 29, 2003 | 07:19 PM
steveRS's Avatar
steveRS
stu you have pm
as you say it should be 0.8mm (32 thou) not 20 thou
20 thou was my first post nd gap was advised by friend
you told me correct and worked spot on!!
steve
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
