escort dash (rev counter) help
Old Oct 20, 2005 | 11:30 AM
rs1300i encore's Avatar
rs1300i encore
Default escort dash (rev counter) help
hi guys, im new here! just been looking on internet and magazines for some help on my escort, and came across this site and thought you guys might be able to sort my problem.
iv got a ford escort 1996 1.3 cfi encore (im 17!! insurance!!). iv done a few things to it, mudflaps, spotlamps, cd player not much, but iv recently bought higher spec dials from ebay. now everything works apart from the rev counter. im not sure how to wire it up. i know usually green wire off the coil, but this things got full electronic ignition. so i avnt got a clue!!
so anyone knows could they please let me know!! thankyou for taking the time to read this!!!
Old Oct 20, 2005 | 05:12 PM
rs1300i encore
Hi guys, after abit of reading wiring diagrams and research, i think i know how to wire it.
Aparently pin2 of the edis module is ment to go 2 a rev counter. this wire is present on my module but i have no idea where it goes. because i really dont have time 2 find out, im thinkin scotch connecter, straight 2 the binicle plug! does this sound about right, i hope so!! will try later!!
Old Oct 21, 2005 | 02:15 PM
CosRush's Avatar
CosRush
I'd suggest before you go altering the wires in any way, try connecting the wire by pushing it into the connector so it makes contact with the terminal holding the wire you are refering to.
this way you can check you do indeed have the right wire, and if so, then go ahead and connect to it, if not, then you haven't got to patch up the wire you've just put a cut in........
make sense??
Hope that helps...........
Old Oct 21, 2005 | 04:43 PM
rs1300i encore
hi guys, did it last night, and it works fine, thanks for your infomation, if anyone wud like to know how to wire up a rev counter on a cfi engine il be more than happy to help!!
thanks very much!!!
andyrs1600i
Sep 4, 2015 06:34 PM
cozzy jeff
Aug 31, 2015 04:14 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
