anti lag,
g unit are gay but like ho i did the
jano oddkid or engine advantages mate. go for aftermarket and get somebody like karl to map it properly. dont go for cossie management as its not really the best of things when there are cheaper better aftermarket kits out there. if your going for cossie management p8 all the way.
jjjjj jano
Anti lag
Any toasted valves and turbo's gen
Imo theres no point on a road going car,running autronic(or similar)you can set the antilag to a bare minimum where it'll work more as a sound and light show than actually keeping the turbo spooled up.
If you must all you need to do is have the igntion retard so the flame front escapes while the ex valve is open,add a wee bit of fuel(possible run a 5th or cold start)and hey presto one melted turbo
i mean antilag
Imo theres no point on a road going car,running autronic(or similar)you can set the antilag to a bare minimum where it'll work more as a sound and light show than actually keeping the turbo spooled up.If you must all you need to do is have the igntion retard so the flame front escapes while the ex valve is open,add a wee bit of fuel(possible run a 5th or cold start)and hey presto one melted turbo
i mean antilag Thread
155lee
Oct 24, 2015 11:11 AM
