PISTON QUESTION
Old Nov 21, 2003 | 09:35 PM
Default PISTON QUESTION
Would any one be able to identify a set of pistons by number on them please?
They are from a Cosworth
MAHLE Pistons
on the top it has : SP0,05 and 91,775
on the underside it has : MAHLE 90P44W2+
If anyone could tell me spec, low comp etc !!
Thanks
Old Nov 22, 2003 | 11:48 AM
Mark_w's Avatar
Mark_w
looks like they are standing comp 1mm oversive pistons
Old Nov 22, 2003 | 05:08 PM
What do you mean by "standing comp"
Does this mean they are low comp ?????
Are they uprated ??????
Old Nov 22, 2003 | 05:50 PM
Mark_w's Avatar
Mark_w
as they have the writing on the piston top it means they havent been machined so should be standard 8 to 1 comp......the number is also very similiar to the standard 2wd mahles i have taken out of my cossie,but the ones you have are 1mm bigger than standard......are the gudgeon pin holes offset???? the only sure way to work it out is by measuring them though
mark
Old Nov 22, 2003 | 06:22 PM
Toe Knee's Avatar
Toe Knee
As said all the numbers are right for standard pistons bar the 91.775 as standard are 90.775 so urs are obviouslt 1mm oversized.
Old Nov 22, 2003 | 08:52 PM
Do standard pistons have a large dish on the top of the pistons ?
Old Nov 22, 2003 | 08:59 PM
Toe Knee's Avatar
Toe Knee
Yea mate, althou depends on ur definition of large lol
Old Nov 22, 2003 | 09:03 PM
IM building a new bottom end and these came from a 400ish bhp 3door,
I was told that they were low comp !
Are they worth much,no marks etc as i will just sell them and get propper low comps.
Can you get them machined ?
Old Nov 24, 2003 | 05:56 PM
Default Pistons
How much you recon they worth
Old Nov 24, 2003 | 08:35 PM
Smit's Avatar
Smit
The 60ft Launch King
packet of scampi fries maybe
Old Nov 25, 2003 | 07:26 AM
Chuck in some pea nuts and we have a deal
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
