Rear brake (pressure reducing?) valve
Old Sep 13, 2005 | 04:19 PM
rocky_robin's Avatar
rocky_robin
Default Rear brake (pressure reducing?) valve
Hi.
My 3dr is leaking at the rear brake line section (near to the rear passenger side axle) It's the hex'd unit which is in line with the brake line, BEFORE it goes into the 3 way split.
See attached photos of them. (from someone else's car who had the same problem as me!!)
Could you tell me what it does and anyone got one spare? Ford stopped making them!
It leaks through the tiny hole below the elastic band that is around the small area. I thought that it may be a pressure relief, but it leaks (seeps) when I pump the pedal. Only a TINY amound comes out when I hold the brakes.
Many thanks in advance!
Old Sep 13, 2005 | 10:51 PM
cossiemen's Avatar
cossiemen
Whassup
brake pressure control valve
they all start leaking, including mine, found a MINT secondhand one on some RS forum
try the FORD COSWORTH RS PARTS FOR SALE room onhere mate or ctc. SPADGE onhere
Old Sep 14, 2005 | 07:05 AM
rocky_robin
You @%@Ł:@Ł"Ł(O %&*&%*&!!!!!!!!!!!
If only I had logged on earlier!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
I don;t like my cossie no more!
Old Sep 14, 2005 | 12:14 PM
cossiemen's Avatar
cossiemen
Whassup
ermmm... what you mean mate? English please?
I know Ford stopped making them but give any of the traders onhere a try for a good secondhand one.
cheeRS
Old Dec 29, 2008 | 01:55 PM
JanDK's Avatar
JanDK
HI all.. found this old thread with a very iritating parts as subject.
Do anyone know if there is an alternativ to this FORD brake reduction valve??
One of my friends have a rather leaky one on his Sapphire
original
Apr 28, 2026 05:20 PM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
