steering problem
Old Nov 21, 2003 | 03:26 PM
THE RADMAN's Avatar
THE RADMAN
Default steering problem
the wifes car has started playing up, its a 1.6 zetec escort and the steering keeps going all vague, its like a delayed reaction, if you turn the wheel nothing happens for a second or so, seems to be ok at around 20mph or less, but its kind of like driving on ice,is this a symptom of the power steering pump on its way out? it had a new rack fitted about 6 months ago, so i assume thats ok, the steering column joints are tight , any ideas?cheers for any help, nick
Old Nov 21, 2003 | 09:55 PM
stopdriving on ice then!!! only yolking m8 have you checked the bottom ball joints and wish bone bushes i think ythey have wish bones other than that when the rack was changed did the track rod ends get changed? only other thing i can think of have you checked the tyre presures. hopr this helps m8.
just read your post again have you checked there is plenty of fluid in the resevoir.
Old Nov 22, 2003 | 08:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Could be air in the system too.. is it notchy to turn?
Old Nov 22, 2003 | 08:52 AM
THE RADMAN's Avatar
THE RADMAN
no not notchy at all,just seems to have happened in the last couple of days,its too dangerous to drive,im going to have a good look today and check out everything else,and of course its pissing it down outside
Old Nov 22, 2003 | 09:12 AM
Check the rubber insulator half way down the steering coupling hasnt torn.
Old Nov 22, 2003 | 11:20 AM
THE RADMAN's Avatar
THE RADMAN
sorted!!!!! everything checked out ok until i went under the car, got the wife to turn the steering and noticed that the whole rack was moving side to side!!! the mounting bolts where it fits on to the subframe were loose!!!!! all sorted now, iv'e just got to get the tracking redone,cheers for help anyway folks, nick
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
