BD10 Camshaft specs?
Old Jul 1, 2004 | 01:58 PM
mach's Avatar
mach
Default BD10 Camshaft specs?
Hi there folks!
My mate is thinking of buying a set of BD10 camshafts from Piper for his EsCos, but if we look it up on Piper or search for specs on the www, we come up with empty hands , so is there ANYONE who can tell me what the specs is on a set of BD10 camshafts?
- Is there any difference on Kent BD10's and the piper version? is there any more info about this we should know?
TA
Old Jul 2, 2004 | 07:34 AM
mach's Avatar
mach
can't anyone help?
would be nice to know what the cams will do to his machine, before we install it
thanks for any help
Old Jul 4, 2004 | 10:46 PM
Andymancos's Avatar
Andymancos
hi mate the Kent BD10 specs are :-
power band 1500-6500rpm
about 15-20bhp if your lucky
Old Jul 5, 2004 | 07:29 AM
mach's Avatar
mach
thanks mate , but do you have any idea of what degrees we are talking about on BD10's, what's the sharpness?
Old Jul 5, 2004 | 04:00 PM
Andymancos's Avatar
Andymancos
cam lift inlet/exhaust .337''
valve lift as above
duration 264 deg
timing figures 17/67 62/22
inlet at full lift 115deg
exhaust at full lift 110deg
Hows that
Old Jul 7, 2004 | 07:16 AM
mach's Avatar
mach
Fcking great!! thanks mate, your the man
Now my final question, maybe where did you find these specs, i've searched high and low for them
Old Jul 7, 2004 | 04:58 PM
Andymancos's Avatar
Andymancos
Ive got a big brain nah ive got a kent cams booklet tells you everything for all cams for all cars knew it would come in handy sometime or other
Old Jul 8, 2004 | 07:06 AM
mach's Avatar
mach
great, maybe one should invest in that booklet, or just write and ask you next time :-D - thanks for ya help mate
Old Jul 8, 2004 | 03:42 PM
Andymancos's Avatar
Andymancos
just ring kent cams mate ask them send you a leaflet on all there cams they should send the same as i have
Old Jul 9, 2004 | 12:51 AM
2001ode's Avatar
2001ode
Hi,
You can find too theses spec on Burton Power catalog.
Regards.
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Marino
Sep 12, 2015 11:10 AM
