Low comp? Opinions please!
Old Nov 21, 2003 | 11:41 AM
gurnE's Avatar
gurnE
Default Low comp? Opinions please!
Time for a rebuild to get rid of piston slap (worse than it should be, always there a little)
At the moment the cars only running greens & 3bar
Gonna go to T34 and maybe a live map on greys or similar.
If I don't plan on going past that point is there any point of going low comp??
Anyone know how much 4x4 piston lower comp by when fitted to a 2wd and are they a direct fit?
Edited to add opinions on long studding too please!
CheeRS
Old Nov 21, 2003 | 11:57 AM
Darrone's Avatar
Darrone
I wouldn't mind knowing the answers to this as well!
Old Nov 21, 2003 | 12:05 PM
smokey's Avatar
smokey
Ditto!
Old Nov 21, 2003 | 06:17 PM
from what ive been told there would be no point in going for low comp pistons if the cars running fine and you dont intend to mod the engine any more they are direct fit the main diff between normal and low comp is they have a smaller height alowing more room in the engine a cheaper way off getin the effect of low comp pistons is to have your orginal pistons skimmed this giving you the same effect and it would allow you to change the compression ratio of the egine not sure by how much tho but it will allow you to run serouis boost prices vary but try burton power they sell em and can skim pistons to, hope this has helped you a bit im in the same postion with my FRST to have pistons skimmed or buy low comp??
frstboy
Old Nov 21, 2003 | 06:51 PM
swerv's Avatar
swerv
im sure you must mean machined and not skimmed
Old Nov 22, 2003 | 06:14 PM
same diff mate
Old Nov 22, 2003 | 06:54 PM
Guinnless's Avatar
Guinnless
swerv's right.
Machined is not the same as skimmed. If you skim 'em you bugger up the squish area.
To answer gurnE's original question. Assuming the engine is untouched from new then fitting 4x4 pistons will bring the CR down to 7.8:1.
I'll be going greys on a Stu live map with standard 8:1 fairly soon. That's the plan anyway.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Tank Mike
Sep 26, 2015 08:07 AM
