tapping cosworth
Old Sep 9, 2005 | 06:26 PM
sbon's Avatar
sbon
Default tapping cosworth
Can anyone help me?
A tapping noise has developed, it is coming from the head. I have replaced the tappits but it is still the same, and I think it is louder. I have had the engine re-built in the last six months, so I know its not the bottom end. Is there a special way to fit the lifters?
All help would be apriciated
Old Sep 10, 2005 | 02:49 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you checked the oil pressure
Old Sep 10, 2005 | 03:09 PM
Dave Henshall's Avatar
Dave Henshall
are the studs for the cam shaft caps ok on the exhasut side, the ally goes weak due to the heat and they strip out allowing the caps to lift and cause a rattkle and in extremes snap the shaft
Old Sep 10, 2005 | 05:43 PM
sbon's Avatar
sbon
Thanks I have checked the cam caps and talked them down. The oil pressure is OK, thanks for your advice any more aprichiated.
Old Sep 11, 2005 | 04:50 PM
boost mad's Avatar
boost mad
could be the valves hitting the pistons, check the cam timing
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
