st24 key fob??
Old Sep 7, 2005 | 06:24 AM
spitfire_bob's Avatar
spitfire_bob
Default st24 key fob??
Hi,
Changed the battery in my key fob but now when unlock button is pressed nothing happens & I have to unlock/lock doors using key.
Is there a code/button pressing sequence to do 1st???
Bob
Old Sep 7, 2005 | 06:26 AM
Willow's Avatar
Willow
I believe that you have to change the batteries within so many seconds or the key fob gets blocked - best visit your local deal!!!
Old Sep 7, 2005 | 12:47 PM
CossieEdd's Avatar
CossieEdd
I believe Willow is correct in that you only have something like 15 seconds to swap the battery before the key decodes itself.
If you've got another two coded keys then you can re-code your remote from them - see the owners guide in the glovebox !
If you haven't got two coded keys then it is indeed time for a trip to the dealer !
HTH
Edd
Old Sep 7, 2005 | 01:58 PM
Shanny's Avatar
Shanny
http://www.mirez.co.uk/KeyProg.htm
This should be helpful.
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
TC-ST3
Sep 26, 2015 04:47 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
NC53
Sep 13, 2015 03:05 PM
