DIY stage 3 saph - what plugs???
I have a DIY stage 3 saph cos - done by previous owner.....
its currently set to 15psi boost, peaks at 17psi - once i have done a few bits, i plan to get it setup to run about 20-22psi if possible
what spark plugs do i need?
been told several different types by various tuners, seems like I could bung any plug in according to the differences in opinions i got!
Cant remember any of the dam part numbers i was told tho so any help and prices much appreciated
1 Post
for std and stage 1 the Motorcraft AGPR12PP8 plugs are spot on, if going more boost, heard people who have had the tips melt off, the Motorcraft 071C are cheap and dont melt and give good cold start and idle running aswell as no on boost misfires.
Originally Posted by Dave Henshall
AGPR701C non surpressed.
finis code:5099754
price roughly:2.30 each
finis code:5099754
you will be hard pushed to find 701's now.. they have been superceded by 071C
AGPS071C
finis - 1120834
Ł11.23 a set incl. vat retail
nice and cheap and work fine
AGPS071C
finis - 1120834
AGPS071C
finis - 1120834
AGPS071C
finis - 1120834
Put 071`s in mine , had denso plugs in it before , with no problems , these 071`s make my car idle funny up and down slightly where as it used to be fine , may need gaping changed though so should work out okk running 1.5 bar
ford do them for about Ł12 a set and the finis is 1120834
thanks for information fellas - i bought the car from pugo off here and he did tell me what plugs to use but i cant remember and havent had them out yet to look. Thought i would ask for a few more opinions and see what teh outcome was. My idle is a bit poo in the morning but other than that it runs good. I think they are 071's - when i heard they were cheap i kinda thought nah it cant be them its bound to be the super expensive plugs that i need - just dont wanna melt them on boost!
wat about denso plugs? i run them, they need chaning now, runs spot on, where do i get em from?
rang up halfrauds and they have nkg's which are Ł11 which is cheap how much are the denso ones?
my car is stage 1 remapped
AGPS071C
finis - 1120834
AGPS071C
finis - 1120834
And also they say that the AGPS 071c (1120 834) has been superceded by 5099 773....?????
Soooo..........
Russ Payne
25-09-2015 08:29 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
