why does my cossie cut out????
Old Aug 28, 2005 | 11:28 AM
cossiegreg1's Avatar
cossiegreg1
Default why does my cossie cut out????
please help my saff cos cuts out on me, it seems to be when the car has warmed up fully,i have changed leads plugs dizzy and coil.is there a sensor somewhere that could cause this??any help aprecciated thanx
Old Aug 28, 2005 | 04:06 PM
rsjohn's Avatar
rsjohn
ECT sensor gives ecu signal how hot engine coolant is so can adjust fueling and idle valve.
john
Old Aug 28, 2005 | 06:48 PM
greg palmer's Avatar
greg palmer
hi, had an 88 2 wd cossie (new) and it suffered from a faulty coil......warmed up and went short cct, stop, cool down, start again....have you tried that ?
Old Aug 29, 2005 | 09:04 AM
cossiegreg1
i have changed the coil about two weeks ago,the car done before i changed the coil aswel but never done it as much as it does now.it maybe used to do it once in a while but now it seems to be when its warmed up especially after iv give it a little boot.Also when it does fire back which takes a few turns,there is quite a bit of smoke(blue/black).i have just changed the turbo for anew one,i have also topped the water up cos it was on the min,as it has always been since owning the car.any help aprecciated thanx p.s where do i find that sensor at mate,how much?
Old Aug 29, 2005 | 09:22 AM
rsjohn's Avatar
rsjohn
You will find it at the back right side near dipstick. its a blue sensor. Prices vary from 99p - £25. I got a new one off ebay for £4.99.
john
Old Aug 31, 2005 | 07:19 PM
cossiegreg1
anyone have any more ideas????
Old Aug 31, 2005 | 07:58 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Phase sensor, TDC sensor??
Same problem twice, i replaced the sensor and the problems where gone.
Phase sensor is located in the dizzy, TDC sensor is lokated at the crank pully
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
