1.4 EFI Escort R reg leaking oil, common places please?
As above, my friends escort is leaking oil somewhere, hard to see where exactly as haven't had a good nose underneath, i've already changed the rocker cover gasket as that was leaking but still has a problem.
Im thinking its probably the sump gasket, is this a common thing to go?
I have changed the sump plug and is still leaking, cheers for any help Matt.
Escort Rs Turbo
Have a look underneath if there is oil on the sides of the sump then it might be that mine whent on my efi. sump gaskets are only about £8-£10 from the motor factors.
JoeyBoyden
18-08-2015 10:52 PM
