t3 turbo wastegate
Old Aug 11, 2005 | 08:43 PM
oriont's Avatar
oriont
Default t3 turbo wastegate
do the penny washers inside the esrt wastegate housing wear??
reason i ask is that ive been loosing boost on my car and i took the housing off to see if this was the problem and i noticed that the washer will not sit flat against the hole as it appears to have worn.
when it is fully shut it is not level with the exhaust housing.
anyone had this trouble or knows a bit more about turbos??
thanks
Dave
Old Aug 12, 2005 | 08:02 AM
JesseT's Avatar
JesseT
Haven't seen one actually wear. Also the washer should be a bit loose so it will always sit flat.
Old Aug 27, 2005 | 08:02 PM
oriont's Avatar
oriont
thats the problem.
when you look at the elbow across the flange that would bolt to the exhaust housing the washer is at an angle so that it would only contact fully along one side.
as if its worn or bent.
thanks
dave
Old Aug 28, 2005 | 10:21 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i have a spare 1 if any help elbow+washer built up, i got in box of spares just give us a shout and il sort something out for y,tommy
Old Aug 28, 2005 | 02:48 PM
Moonie's Avatar
Moonie
Also look for cracks in the exhaust housing which can result in reduced boost
Old Aug 28, 2005 | 04:10 PM
rsjohn's Avatar
rsjohn
I had that problem on T34 i bought!! the spindle arm was bent slightly, so adjusted it with a small hammer and it moved more freely and seated properly.
john
Old Aug 28, 2005 | 07:43 PM
oriont's Avatar
oriont
thatnks guys,
treid 'adjusting it ' this afternoon, now it has a crack in the arm
Tommy give us a pm with what you want for it pal
i assume ther all the same regardless of what stage t3 you have
thanks
dave
Old Aug 28, 2005 | 08:28 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
sent you a pm any one know any differances are they the same
sorry forgot to say one of the stud holes are oveled you may need to nut and bolt but will b okay
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
