Is my ecu chipped or not ?
Old 03-08-2005 | 12:16 PM
TGTURBO's Avatar
TGTURBO
Default Is my ecu chipped or not ?
Just wondering if any one can give me some advise on my ecu . I brought my S2 3years ago it was running 14psi. had the engine rebuilt this year and went to have it set up but tuner recons it hasnt been chipped.He told me to take a look at the ecu and take it a part to see if it had code or a tuners name or initials in it . took it apart and it had ford waranty seals on the side and told the tuner it has not had the warrenty seals broken but wanted to ask for a second apinion first as he said i need a chip please help
Old 03-08-2005 | 03:00 PM
mart.rs's Avatar
mart.rs
was it holdin or peaking @14psi,i if holdin its definitly chipped,if its peaking on full throttle then dropping back to say 9 and 1/2 its definitly not chipped!
Old 03-08-2005 | 03:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
As above if it holds 14psi then its chipped if it was just going up to 14psi then dropping back down to 10psi or below then its not chipped as you cant run a standerd ecu without a chip over 10psi
Old 09-08-2005 | 01:56 PM
TGTURBO's Avatar
TGTURBO
thanks for your help fellas but not woriying about it now mate as i have decided to go cossie management+cossie hybrid+anti-lag R let u now how i get on
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
griffo69
04-10-2015 11:58 AM
A.t.p
29-09-2015 05:04 PM
Quick Reply: Is my ecu chipped or not ?
