is a dump valve needed
Old Jun 23, 2004 | 06:47 PM
ian rst's Avatar
ian rst
Default is a dump valve needed
Is it needed on a escort cossie running 24 psi? simple as that.
Old Jun 23, 2004 | 07:18 PM
wimwerf's Avatar
wimwerf
Hello Ian,
when you going to run 24psi of boost it is better for the bearings of your turbo. they live a while longer with a dumpvalve then without one. don't you like the sound of a dumpvalve.
best regards,
Old Jun 24, 2004 | 06:28 AM
ian rst's Avatar
ian rst
Yeah but i like the sound of chatter better, i will leave the dump valve on then. cheers
Old Jun 24, 2004 | 07:20 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
ian: i have run 25psi thru my t34 for 9000 miles now WITHOUT a dump valve and it hasnt caused me any props. I no someone who runs 37 psi without a dumpvalve and his engine has done 30000 and is still as good as day 1.
Choice is yours IMO. Chatter is better and i find throttle response is better without a d/v anyway.
Rich
Old Jun 24, 2004 | 12:11 PM
ian rst's Avatar
ian rst
Ok another question how do i take the dump valve off but still making sure the gauge works? I have traced the vacuum pipe back to the side of the block where you screw a T piece in but if i take it out the gauge wont work surely?
shortie
Aug 19, 2015 01:01 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
col93saphcos
Aug 7, 2015 03:21 PM
