rs 2000 fan dont work
Old Jun 25, 2005 | 07:35 PM
wimble's Avatar
wimble
Default rs 2000 fan dont work
i cant get the fans to work on my girl friends j plat rs 2000
i have replased the fan switch fuses and checked the wiring and the fuse box and couldnt see eney thing wrong at the moment she is driving me potty please help
Old Jun 26, 2005 | 12:57 PM
davidreader5's Avatar
davidreader5
HI,
Is there any power @ the thermo switch,(the switch that kicks the power to the
fan) i think on the rs 2000, the ecu runs the fan, so you cant bypass the thermo
switch, like on the rs turbo escort. as you will blow the ecu, if no power to switch
and the fuses are ok, try the relay if you can find it.
DAVE R,
Old Jun 26, 2005 | 01:49 PM
Al Bags's Avatar
Al Bags
Test the relay supplies and outputs at the relay position.
It's possible you have a Fuseboard going down.
You had a new Fusebox in this at all? Tested all the circuits from the board for operation?
Old Jun 26, 2005 | 04:08 PM
wimble's Avatar
wimble
there has been a new fuse board fitted apparently this was doon by the previous owner i did check the fuse board and every looks in good condition
which relay is for the fan
Old Jun 27, 2005 | 12:55 PM
16vzetec's Avatar
16vzetec
this always happens.
usually fusebox failur, this is the most common problem on the mk5/6 escorts.
you can bypass the fusebox with a wire from the ignition switch to the fan power wire.
ive done loads of them.
infact i just done one yesterday that wouldnt start but i bridged some wires and now it goes
Old Jun 28, 2005 | 09:27 AM
wimble's Avatar
wimble
i will try tonight thanx
Vacuman
16
Sep 3, 2015 06:26 AM
jaysoc1
Aug 21, 2015 05:38 PM
jaysoc1
Aug 20, 2015 08:18 PM
Zoggon
Aug 10, 2015 10:39 AM
