Combustion chamber volume
Old Jun 20, 2004 | 02:20 PM
mikkel's Avatar
mikkel
Default Combustion chamber volume
Can anyone tell me the cc.on a standard 2wd combustion chamber and the thickness off the Head gasket.
Thanks
Old Jun 20, 2004 | 03:59 PM
MadMac's Avatar
MadMac
ERM, needle in a haystack! What car? What engine? Turbo or N.A???? petrol or diesel
Combustion chamber size isn't measured in cc's its measured by the ratio to which the pisont compresses the air fuel mix in the cylinder. Say 10:1 is typcal for a petrol N/A car, 15:1 for a Diesel, 8:1 for a turbo.
Old Jun 20, 2004 | 04:14 PM
mikkel's Avatar
mikkel
OH, I forgot to say this was about a Sierra Cosworth.
But about MadMac's post,how can you calculate the compression ratio if you don't
know the volume of the chamber+gasket,hrmm
Old Jun 20, 2004 | 08:32 PM
Stu @ M Developments's Avatar
PassionFords Creator
MadMac,
He wants to know the actually clearance volume in CC.
The easiest and most accurate way to measure this, and many will disagree, but it works fo me, is to bolt the head onto the block with engine set to compression TDC and using a BURRETTE measure the amount of fluid required to fill up to the spark plug hole.
That will give you asn accurate clearance volume, then you just need to add your swept volume into the equasion and bobs your mothers brother
Old Jun 20, 2004 | 08:39 PM
MadMac's Avatar
MadMac
You can work out the clearance volume by using the cc of the engine and the compression ratio cant you?
Yeah, didn't think about using a burrette to mesure it, that will be usefull to know cus I always did it by dividing the swept volume by the compression ratio.
Old Jun 20, 2004 | 08:55 PM
Yes, but what happens when you dont know the compression ratio? say youve skimmed the head and the block, and are using pistons that you have machined valve pockets into?
Old Jun 21, 2004 | 02:51 PM
MadMac's Avatar
MadMac
All good stu all good, you learn something new every day!
`spotty
Sep 25, 2015 11:41 PM
Russ Hill
Aug 31, 2015 06:44 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Old ford
Jul 31, 2015 06:50 AM
Mark_w
Sep 26, 2003 01:37 PM
