ERST OIL LIGHT FLICKERING ???
Old Jun 11, 2005 | 10:13 PM
DaveN's Avatar
DaveN
Default ERST OIL LIGHT FLICKERING ???
As above fitted 2 new switches and it still flickers only on tickover and only after about a 15-20 minute run ??Checked for dirt on the valve and so on and the engine had a full rebuild 20,000 miles ago and a new oil pump was fitted ?? I aint running the car till this is resolved. If i get gauges etc for checking the oil pressure where exactly is the point for checking the pressure, also what should the pressure be? Any ideas folks as the car is still running and sounding sweet>> Any help - very grateful. I will probably install a oil pressure gauge once this is fixed..
Has anyone else had this problem..
Old Jun 12, 2005 | 06:47 AM
Alvyn's Avatar
Alvyn
if you T off from where the oil light switch bolts to the block is you should be able to get a good reading from there,tick over should be around the 25lbs IIRC.
so it's ok when cold? if so try using a different oil?
Old Jun 12, 2005 | 08:55 AM
DaveN's Avatar
DaveN
Cheers Alvyn, ive been using valvloine turbo V since the rebuild, changing evry 3000.
Old Jun 13, 2005 | 09:56 PM
glenrs2k's Avatar
glenrs2k
A mate had a similar prob when the car was being driven the oil light stayed off but when ideling was flickering turned out to be the oil pump
Old Jun 14, 2005 | 02:39 PM
rich2302's Avatar
rich2302
sounds like either oil pump or wrong oil, is it ok from cold and the problem only starts when hot, and how much oil was it using?
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
