mk4 1.4 cvh bad idle
Old Jun 1, 2005 | 11:35 PM
uusmatt's Avatar
uusmatt
Default mk4 1.4 cvh bad idle
I've had this problem on 3 cvh's, 2 * 1.4 and 1 * 1.6. now they were all carb's, when this problem crop's up all i have to do is clean out the jet's in the carb's and they have all run perfect. my latest car also has this problem. now, i have personally dismantled and cleaned the carb's, i have had the fuel tank's and fuel lines cleaned and have never managed to solve the problem. I have even inserted fuel filter's just before the carb's to no joy.
This must be a common problem as i have had it in 3 cars out of 3/ so, have i missed something in the carb or is something getting throught he fuel filter (asuming the filter actually removes all the dirt and the tank is clean)
any help is much appreciated.
Old Jun 2, 2005 | 08:31 PM
haz87's Avatar
haz87
vacuum leak or gasket leak
Old Jun 4, 2005 | 06:48 PM
zippyobrien's Avatar
zippyobrien
hi,
the problem is likely to be a split gasket between the carb and the engine, to find the split gasket, use wd40 of carb cleaner and spray it on each of the gaskets, the revs will rise when you spray the fluid on the split gasket. you then replace that particular gasket insuring that you clean the mating surfaces well
mk3ste
Oct 17, 2021 10:09 AM
Fordmad!
Sep 29, 2015 07:03 PM
Orion_Gav
Sep 29, 2015 04:50 PM
deathrider666
Sep 28, 2015 06:12 PM
