big turbo escos lambda probe
Old May 31, 2005 | 06:28 PM
Dave Henshall's Avatar
Dave Henshall
Default big turbo escos lambda probe
its reading 1.2 volts all the time across pins 1and 2 back at the ecu. took it out and it was all black, last time i took it out was when i did the head gasket and it was white (doe to antifreeze contamination) it appears that the anti freeze can kill the sensor.
i've found a replacement on here...
http://www.lambdasensor.com/main/mcolours1.htm
part no : 11014T12 - a 3 wire titania 12mm one.
only trouble is the old one is marked up as NTK D5F, this is also listed on the site but its univeral equililent is a 18mm one?
can someone whos's ordered one let me know the part no and price please.
Matt Baxter
Sep 16, 2015 08:30 PM
Dahl88
Aug 22, 2015 08:16 PM
Blown Hell
Aug 5, 2015 07:22 AM
Escortdriver1
Jul 31, 2015 02:36 PM
