2wd Sapph boost problem
Old May 25, 2005 | 10:00 AM
Mich's Avatar
Mich
Default 2wd Sapph boost problem
Slight problem with the boost at the moment it won't hold over 10psi usually it runs about 20-24psi, I just get what sounds like a rushing of air any idea whats going on
CheeRS
Mich
Old May 25, 2005 | 10:20 AM
2001ode's Avatar
2001ode
Hi,
Look around
AMAL valve defective
Waste gate membrane leaky
Dump valve leaky
Regards
Old May 25, 2005 | 10:42 AM
Mich's Avatar
Mich
It does sound as though its coming from the side that the dump valve is on so would that make sense then for the loss in boost ??
Mich
Old May 25, 2005 | 11:10 AM
rsjohn's Avatar
rsjohn
Is dump valve single or twin piston? if single it will hiss like a leak.
check intercooler as my mates cossie lost boost and it had split at bottom!!!!
john
Karl 3dr
102
Oct 14, 2016 08:17 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Toe Knee
Aug 23, 2015 08:31 AM
pegaz
11
Aug 9, 2015 06:40 PM
