Help with 3dr hatch light
Old Nov 11, 2003 | 11:56 AM
3drSteve's Avatar
3drSteve
Default Help with 3dr hatch light
I have a problem with my alarm door/hatch sensors.
I have noticed that my hatch light is constantly on but cant find the switch.
I have had the trim panel off the u/s of the hatch but cant see anything in there.
Can someone tell me what operates the hatch light?
Steve.
Old Nov 11, 2003 | 12:03 PM
Matt's Avatar
Matt
do you mean that stoopid grraphical display next to the clock? if so then your hatch aint open, mine tells me doors and hatch is open and goes nuts a bit, have now removed the fookin lot of it and put the defi's there (well almost) LOL
Old Nov 11, 2003 | 12:08 PM
3drSteve's Avatar
3drSteve
No its the alarm mate. When i arm it it beeps to tell me there is a door open but there isnt!
Seeing as hatch light stays on thought it might be the hatch.
Interesting about the centre display panel - will check that.
Steve.
Old Nov 11, 2003 | 12:09 PM
or do you mean the little one in the boot - I dont remember installing a switch for this, so assume it works off the ones by the hinges on the front doors.
If you do mean the display light then this is controlled by a little black plastic micro switch that is attached to the side of the hatch lock mechanism inside the hatch itself behind the removable panel.
Old Nov 11, 2003 | 12:11 PM
just saw your follow up note - the alarm will have an independant switch somewhere.
Karl's Avatar
Karl
Norris Motorsport
steve I have exactly the same problem on my 3dr. I'm no expert on the wiring in the car, but I found the boot light to be operated by a tilt type switch found inside the boot near the lock solenoid mechanism. It's a bit tight to get to but can be reached.
Sadly mine seemed to work ok but the light was still permanently on so in the end I just took the plug off the back of the light and it seemed to cure the alarm problem. LOL
Old Nov 11, 2003 | 12:13 PM
Damo V's Avatar
Damo V
Nah think you were right first time, it will be the little micro switch on the lock/catch i reckon..... as the installer will probably have spliced into that..
Old Nov 11, 2003 | 12:14 PM
Damo V's Avatar
Damo V
just read Karls, post, maybe a broken wire between the bootlid and shell, near the hinges, it may be earthing on the body, causing a contact...
Old Nov 11, 2003 | 12:21 PM
3drSteve's Avatar
3drSteve
Thanks lads,
I will have another look after work. There does seem alot going on behind the lock area and I can get all of 1 finger in there!!
Steve.
Old Nov 11, 2003 | 12:23 PM
Damo V's Avatar
Damo V
it should just unbolt and "fall" out....
Old Nov 11, 2003 | 12:25 PM
3drSteve's Avatar
3drSteve
Damo, perhaps its already "fallen" out
Hatch button has always been a bit sticky - seems like a good time to get in bits on the bench.
Steve.
Old Nov 11, 2003 | 12:26 PM
MAD ANDY's Avatar
MAD ANDY
Steve
just have done with the rotten old thing, called Dixies or Bleaseys, get them come pick it up then get yourself a sapph
Old Nov 11, 2003 | 12:27 PM
Damo V's Avatar
Damo V
hmmm good luck is all i can say
Old Nov 11, 2003 | 12:29 PM
3drSteve's Avatar
3drSteve
Andy,
Yep might change it for a saph and earn extra money in my spare time TAXI man.
Old Nov 11, 2003 | 01:00 PM
PJay's Avatar
PJay
Bur deos the alarm still work on the boot, you'll probably find now that it doesn't, had the same prob with mine.
PJay
Old Nov 11, 2003 | 01:05 PM
Karl's Avatar
Karl
Norris Motorsport
No the alarm doesnt work on the light coming on but still activates the proximity sensors when you lift the boot lid so its still protected.
Old Nov 11, 2003 | 01:23 PM
PJay's Avatar
PJay
Didn't think of that, i put a pin switch on mine in the end just in case.
PJay
Old Nov 11, 2003 | 01:24 PM
MAD ANDY's Avatar
MAD ANDY
Originally Posted by 3drSteve
Andy,
lol quickest taxi around though you'd love it!
Old Nov 11, 2003 | 01:29 PM
PJay's Avatar
PJay
you'd love it!
Not sure the old ladies would with all there shopping.
Ohhhhhh young man, mind my shopping!!!!1
PJay
Stu @ M Developments's Avatar
PassionFords Creator
The switch is activated by a mercury tilt switch.
Its a gold coloured thing about the size of an alarm battery installed in the boot lock area.
Adjust the angle of this until it works correctly, they can be set wrongly by lowering the car, fitting hi fi etc.
Moved to tech room in 10 mins
Old Nov 11, 2003 | 01:44 PM
3drSteve's Avatar
3drSteve
Cheers Stu,
Will be attacking it when I get home.
Steve.
Old Jul 31, 2010 | 09:12 AM
These mercury tilt switches can also give problems in hot weather, as the mercury expands a little bridging contacts enough to trip the alarm but not enough to light a bulb, had to replace on my dads 4i for this reason, adjusted angle etc first but on a really hot day still went off.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
The Enigma
Sep 12, 2015 10:12 PM
