Cossie Ign Amp...Different makes...???
Old May 18, 2005 | 11:24 AM
CosRush's Avatar
CosRush
Default Cossie Ign Amp...Different makes...???
Obviously there is the original Ford item, then there is the Huco German one as on Stu@msd'd website, and ive also seen a cossie with an Intermotor 15030 amp....
Just wondered if anyone knew any more about this, and whether any were any better than the otherand what the prices would be....
Old May 18, 2005 | 07:23 PM
yrkesman's Avatar
yrkesman
Default Re: Cossie Ign Amp...Different makes...???
Originally Posted by CosRush
Obviously there is the original Ford item, then there is the Huco German one as on Stu@MSD'd website, and ive also seen a cossie with an Intermotor 15030 amp....
http://www.megasquirt.info/ms2/Bosch_124.htm
Old May 18, 2005 | 07:54 PM
CosRush's Avatar
CosRush
Thanks for that...
Says the 124 doesn't control Dwell though.....thought the Cossie one does....so im guessing they are not compatible.
Old May 19, 2005 | 08:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
personally, i would use a 2 channel bosch one, rather than 2 single ones for a coil pack. well i wouldn't actually use either actually, cos i'll go straight to coil on plug.
Old May 19, 2005 | 08:58 AM
CosRush's Avatar
CosRush
never heard of the bosch 2 channel one...
what cars are they fitted to, and do you know if they could be wired in place of the 2 seperate amps???
I take it even if they could, an L8 would still the board from Secs to make it work...
Old May 19, 2005 | 01:42 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can get single channel, 2 channel, 4 channel (for individual coils) etc.
don't know what they're fitted to as standard, just know that they're available (from IMA for example)
they can easily be wired in instead of two singles, and yes it just needs the board from SECS to work. you still need 2 triggers from the ecu to get each channel amp to fire the correct side of the coil for the correct plug pair
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
