S2 Turbo Smoking
Old May 16, 2005 | 08:02 PM
Dans S2's Avatar
Dans S2
Default S2 Turbo Smoking
I wonder if anyone can give me some advice on my car??
Just recently it has started smoking especially when you start it up from cold, the smoke is white and smells of oil, once it is warm the smoke seems to go although it still smokes on idle as you pull up say at a junction, if you give it some stick smoke comes out of the passenger side bonnet vent, after opening the bonnet it appears to be the turbo where the smoke is coming from. The exhaust is black inside and there are traces of oil, also the oil pressure reads 10-15 on tick over and 35-45 when driving.
Any ideas?? please..
CheeRS in advance
Old May 17, 2005 | 09:08 AM
davidnormanuk's Avatar
davidnormanuk
It sounds like either your turbo is on its way out or your rings are worn. Don't know about the smoke coming from the bonnet vent though.
Old May 17, 2005 | 01:18 PM
Nice_aRSe's Avatar
Nice_aRSe
If the turbo was going you'd be getting blue smoke.
If its white smoke your head gasket has had it, which would also be shown by your low oil pressure
Old May 17, 2005 | 05:57 PM
Dans S2's Avatar
Dans S2
CheeRS for the info. i think it may be turbo then as the smoke has been going blue today when i looked.
Dan
Old May 17, 2005 | 06:14 PM
radiant red's Avatar
radiant red
If the car smokes at idle, on overrun and when started first thing in a morning it could just be your valve stem oil seals, common problem and not expensive to replace. Basically the vacum created by the engine whilst the throttle is shut (ticking over/overrun) causes the thing to draw air in from anywhere it can and if that means pulling air through worn stem seals it will bring the oil with it into the combustion chamber. Also whilst the car is stood overnight the hot oil has time to seep past the seals to the top of the valves so the next time you start the engine it will burn it. Sounds like the oil is leaking onto the turbo, have a good look around mate.
Old May 17, 2005 | 06:55 PM
Dans S2's Avatar
Dans S2
I have thought it may be the stem seals as well, i have a brand new set it the garage so i think i will change them and see if that makes any difference!
Dan
Old May 18, 2005 | 08:35 AM
tizzer0's Avatar
tizzer0
it sounds like when ur car i running on low revs it is back fireing through the carb or if it is white smoke the gasket might of had it.
Old May 18, 2005 | 06:20 PM
Dans S2's Avatar
Dans S2
Have a feelin it may be the turbo, took it off this evening and here are some pics of the underside of it!
[/img]
Old May 21, 2005 | 06:17 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
any more news on the car Dans S2, ?
Old May 21, 2005 | 07:17 PM
Nice_aRSe's Avatar
Nice_aRSe
Mate just get new gaskets for it you may be lucky and thats all it needs
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
rsturbo27
Sep 1, 2015 09:54 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Adam-M
22
Aug 10, 2015 10:46 AM
