air charge sensor (brown)
Old May 14, 2005 | 02:06 PM
need4speed's Avatar
need4speed
Default air charge sensor (brown)
what does it do and could it cause the car to over fuel if broke.cheers
Old May 14, 2005 | 07:19 PM
Rs1's Avatar
Rs1
On a rst??? If it the one in the cross over pipe it a temp sensor for inlet charge,too high a temp and you'll hit overboost.
Overfuelling could be as simple as bad/incorrect setup or even thermotime switch/temp sensor(the blue one under the inlet manifold)
Old May 17, 2005 | 10:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
obviously it measures the temperature of the incoming charge air. that informaion is needed by the ecu to calculate the density of the air, so it knows how much fuel to put with it (this is based on mass, not volume). without it, for safety of the engine, the ecu has to assume that the air is at it's densest (i.e. coldest) and add fuel accordingly. that means that at higher act's it will be overfuelling.
that is the safe way, but i'm not saying that all ecu's and maps are programmed that way. as you don't say what you're talking, who can say for sure?
Old May 21, 2005 | 08:05 PM
davidreader5's Avatar
davidreader5
HI,
ACT sensor, on the signal to the ecu alters the fueling and ignition
also covers operation of turbo boost pressure. above 70degrees(C) approx.
DAVE R.
15
Oct 7, 2015 03:43 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
