rich cossie
Old May 16, 2005 | 07:51 PM
daz1968's Avatar
daz1968
Default rich cossie
Hi there, I am sure I have read about this before, but have no forum search so here it is,
My 3dr had 10%CO for mot and was a failure, It passed last year, and I have altered nothing. After a run the plugs are black, and it does spit black soot out of exhaust, I tried connections on rear sensor on head with WD40 no difference, Any one any ideas, I have no misfires although the car is a bit hesitant to rev, which I presume is due to mixture. I think it maybe one of the sensors gone down, but would appreciate any advise before I start changing them
Darren
Old May 17, 2005 | 12:01 AM
boost mad's Avatar
boost mad
maybe the act sensor, the brown one in the inlet manifold, just a guess tho
Old May 17, 2005 | 06:35 PM
Dave Henshall's Avatar
Dave Henshall
more likely the blue ECT sensor (engine coolant temp) as these generally are more prone to failure and its this which determines whether the ecu fuels the car for cold or hot, if it fails it sees it as a cold engine which will run excess fuel.
Old May 18, 2005 | 07:41 AM
Jay,'s Avatar
Jay,
Sponsor
https://passionford.com/forum/viewtopic.php?t=115550
i had the same prob dave emailed me how to read the rear blue sensor with a ohms meter think from cold it starts at around 3.00 then when hot will drop to 70 if it does its fine then try ur ecu
cheers jay
Old May 19, 2005 | 10:08 PM
daz1968's Avatar
daz1968
Just to let you know I checked resistance on sensors, appeared ok at cold but changed both blue and brown sensors anyway as they are old, left it running till fans cut in and out, then removed a plug, starting to go brown not black so think one of the sensors may of been problem but will confirm weekend when i take it out, but looks ok
Thanks
Darren
Old May 20, 2005 | 12:38 AM
boost mad's Avatar
boost mad
please say it was the one i said..... i never get nething right lol
Old May 20, 2005 | 08:16 AM
Jay,'s Avatar
Jay,
Sponsor
one thing u have got right m8 is that 3rd proper m8 proper
jay
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
The Enigma
Sep 29, 2015 10:31 AM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
