Coswoth Exhaust Manifold
Old May 15, 2005 | 10:33 AM
RyanB's Avatar
RyanB
Default Coswoth Exhaust Manifold
I've just bought a second hand 4x4 exhaust manifold to fit onto my 2wd engine. For some reason it doesn't fit! I have held it up against the 2wd manifold and the stud pattern, especially around the smaller centre holes, is different. Around 2-3 mm different. The part No. on the 4x4 one is YB0625/02. According to the Cosworth parts list the part no. should be YB0625 so what does the /02 mean? I have had the head head helicoiled in two or three places, and fitted brand new studs, and still the 2wd manifold fits like a glove. Any help will be greatly received,
Ryan
Old May 15, 2005 | 02:15 PM
Guinnless's Avatar
Guinnless
Are the studs that have been helicoiled 100% perpendicular to the head?
The manifolds should be a straight swap. I've had both on the same heaf with no issues.
Old May 15, 2005 | 02:22 PM
RyanB's Avatar
RyanB
Default cosworth exhaust manifold
Not sure if the studs are perfectly perpendicular, but the 2wd manifold fits easily.
Old May 15, 2005 | 03:04 PM
Guinnless's Avatar
Guinnless
Distorted manifold perhaps? Or have the bolt holes been enlarged on the 2wd item?
Old May 15, 2005 | 09:32 PM
RyanB's Avatar
RyanB
Default Cosworth exhaust manifold
I've just had some info that tells me i may have the wrong manifold. So I have purchased another to see if it sorts out the problem.
Fingers crossed! Thanks for the help anyway
Old May 15, 2005 | 09:49 PM
THE RADMAN's Avatar
THE RADMAN
didnt know there were 2 types of 4x4 manifold?
Old May 15, 2005 | 10:01 PM
RyanB's Avatar
RyanB
The first one I bought had part no. YB0625/02 According to the Cosworth parts list the 4x4 Manifold should be YB0625. Allegedly the /02 may mean the manifold is from an escort small turbo? Might be right, might be wrong, so I thought I'd give it a try!
gcfcos
59
Oct 6, 2015 05:04 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
caprixpack
Sep 25, 2015 07:53 PM
