4x4 intercooler fitting to a 2wd Saff
Old May 14, 2005 | 01:22 PM
Filthy Rich's Avatar
Filthy Rich
Default 4x4 intercooler fitting to a 2wd Saff
Fitted a 4x4 cooler to a mates Sapphire lastnight only to find the radiator wouldn't fit underneath it
So had to remove it and stick the 2wd cooler back on
Do you have to use a 4x4 rad with the cooler or is there another way to sort it ??
Thanx in advance
Rich
Old May 14, 2005 | 09:41 PM
Alvyn's Avatar
Alvyn
just bend the top radiator lugs down GENTLY so that the cooler fits in u may have to also shorten/cut the boost pipes down abit
Old May 17, 2005 | 10:40 AM
foreigneRS's Avatar
foreigneRS
Testing the future
on mine, i cut off the top lugs of the rad, and moved them across to where they need to be to fit to the 4x4 intercooler and rewelded them.
if you just bend them over as alvyn suggests, the radiator and intercooler will no longer be joined (by the rubber dampers). this could lead to either heat exchanger core failing early through fatigue.
Old May 17, 2005 | 05:12 PM
Filthy Rich
Thanks Nick, that's what i was thinking
He's just going to wait till he can afford a 500 styleeee thing now
Old May 18, 2005 | 03:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yeah, me too. or maybe a chargecooler before the i/c
mrmann
Aug 20, 2015 11:24 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
markk
18
Aug 17, 2015 05:19 AM
RsS2daz
Aug 14, 2015 05:26 AM
Old ford
Jul 31, 2015 06:50 AM
