Rear Shocks
Old May 11, 2005 | 03:36 PM
Moonstone Kev's Avatar
Moonstone Kev
Default Rear Shocks
How easy is it to change the rear shocks on a 3dr cosworth?
Old May 11, 2005 | 04:45 PM
cossied's Avatar
cossied
Default shocks
from inside the car just behind the rear seat you undo the top fixing bolt for each shock, take off the rear wheels and undo the bottom shock bolts pull out the shock. It is a bit tricky when you push the new one up to get it to line up with the top hole if you are on your own, if you have help it is easy. regards
cossied's Avatar
cossied
Default shocks
Old May 11, 2005 | 09:55 PM
Moonstone Kev
Thanks for the info cossied
Old May 11, 2005 | 10:15 PM
Azrael's Avatar
Azrael
You can do it even without taking the wheels off.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
The Enigma
Sep 12, 2015 10:12 PM
Topjoe9
Sep 12, 2015 09:50 AM
cossirob
Sep 3, 2015 09:17 PM
