points to electronic ign
Old May 7, 2005 | 07:33 PM
markk's Avatar
markk
Default points to electronic ign
ok my vans electronic ign has gone fooked , so whats the options , i want cheap electronic ign that prefarably removes the points in the dizzy - any ideas guys , BTW , it a rover V8 so must be compatible with 8 cylinders , im not paying lumenition prices either robbin cnuts
or any other conversions you may have done / fitted ?
Old May 8, 2005 | 10:08 AM
richm's Avatar
richm
may not be cheap enough Mark, but the Magnetronic system from Lumenition is very neat and effective, trigger module replaces points and a trigger disc fits under the rotor arm, no external control boxes.. need to check if they are available for V8 distributor.. ? i'm not sure.
http://www.demon-tweeks.co.uk/catalo...&action=detail
as always, demon thiefs isn't the cheapest place should get the kit for Ł65+vat or thereabouts..
or try Aldon Ignitor - similar arrangement with V8 application
http://www.aldonauto.co.uk/aprods.htm
http://www.demon-tweeks.co.uk/catalo...PCODE=A/A1847V
Old May 8, 2005 | 11:20 AM
markk's Avatar
markk
cheers rich , i didnt go into the whole story tbh , but i had the aldon ignitor in until recently when it decided to pack up intermittant non start/cutting out with no spark, but was working fine for about a year just wondered about my options thats all, but i think these two youev said are about t he easiest and the cheapest.
cheers
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
