escort gearbox markings??
Old May 6, 2005 | 10:23 PM
G420 DEL's Avatar
G420 DEL
Default escort gearbox markings??
just a little question
are there any markings on gearboxes so u can tell which is the rs LSD box or say a 3I box??
think i saw some numbers on the n/s of my box on the diff housein would this be the number?
cheers Ric
Old May 8, 2005 | 01:06 PM
G420 DEL's Avatar
G420 DEL
no 1 know more then me?
Old May 8, 2005 | 08:00 PM
matty872's Avatar
matty872
I think if you look through the hole where the driveshafts go in on a box with an lsd you should be able to look straight through with nothing crossin the hole 2 other side. on 3i box there is a bar that crosses the hole. Dont quote me to this though! I aint sure.
Old May 8, 2005 | 10:45 PM
GrimmeRS2K's Avatar
GrimmeRS2K
just jack it up, turn one wheel, if the other wheel moves, it has a lsd
Old May 8, 2005 | 11:27 PM
RSeb's Avatar
RSeb
both those replies are definately right
Old May 9, 2005 | 09:56 PM
G420 DEL's Avatar
G420 DEL
knew about the spinnin the wheel one just wasnt sure if i was lookin at a box off a car so i didnt get a wrong un
cheers
Old May 9, 2005 | 10:32 PM
Aragorn-'s Avatar
Aragorn-
maybe im talking out me arse here but im almost certain the std diff will rotate the other wheel the opposite direction if both wheels are off the ground and u turn one side?
so perhaps a sign of an LSD would be they both turn the same way?
Old May 10, 2005 | 07:59 PM
ad's Avatar
ad
hello mate when u turn 1 of the wheels the other should turn the same way and the code on the box should start with the letters WFO i think i hope that helped u
Old May 11, 2005 | 10:44 PM
rsjohn's Avatar
rsjohn
Your gearbox is an S2 box with uprated bearings and lsd.
Unless it was changed from when McPikey had it.
john.
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
