actuator advice please!!!
Old May 6, 2005 | 08:19 PM
chorton's Avatar
chorton
Default actuator advice please!!!
I've just replaced the turbo on my S2 and have noticed some severe "twisting scratch marks" on the shaft of the actuator, where it looks like someone has turned the shaft with a pair of mole grips or pliers. Now I'm sure I read somewhere that doing that will knacker the actuator, is that right? Car seems to boost fine, would it be worth replacing or not?
Old May 6, 2005 | 08:23 PM
Niall.b's Avatar
Niall.b
probably somebody has used pliers/vise grips to hold it during adjustment in the past & the threads have been tight. if its boosting ok. keep it lit
Old May 6, 2005 | 11:50 PM
Dean Saff's Avatar
Dean Saff
I would think it could damage it, maybe split the diaphram or somthing...
But as Niall.b says if it works dont try and fix it.
Old May 7, 2005 | 11:50 AM
Stu @ M Developments's Avatar
PassionFords Creator
Yes, this risks damaging the diaghragm, thing is, when it finally does go, your likely to be informed of it by a conrod popping out the front of your engine block as the boost hits excessive levels.. lol
Old May 10, 2005 | 08:10 PM
richm's Avatar
richm
unfortunately probably not that subtle.. usually lazy bastards who can't be arsed to disconnect the turnbuckle from the wastegate to adjust it, and just twist the rod instead
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
