Escort Cosworth Fuse box.
Hi all,
Got a 93 Escort Cosworth, had it over 11 years. Had a new fuse box fitted 5 years ago and understand the mk 5 suffered with this fault. Seem to have a similar problem again whereby the fuel pump wont cut in. If i run a live to the cut off switch it runs ok, pump must be ok then. If i take a voltage reading from the supply side of relay 9, 12 volts ok, but if i link relay 9 supply and feed i lose the voltage. Would this suggest fuse box prob? any ideas please.please, please
Yeh, swopped it with another the same. still didnt cut in. I have however run another feed to the supply side of the relay and everything works fine. Seems like it must be the supply to the relay from the feed to the fuse box.
Another fuse box I suppose. Thanks anyway.
sridgett
18
01-08-2015 08:49 PM
