air bag light escort td
Old May 4, 2005 | 08:12 PM
matty872's Avatar
matty872
Default air bag light escort td
I brought a mk6 escort 1.8td 2 months ago and the other day my airbag light started flashing.It flashes 4 times then pauses n keeps on doing it,does this mean anything(is it a fault code)? If i can find out where it has gone wrong I can sort it as we deal with airbags at work.Your help would be much appreciated.
Old May 6, 2005 | 01:10 PM
o n i o n's Avatar
o n i o n
I think four flashes indicates a faulty pre-tentioner.
They had big problems with the yellow connectors under the trims by the outside of each seat.
You want to try disconnecting these and putting a small amont of vaseline (ooh er) in the connector block and reconnecting.
Make sure you have the battery disconnected for about 10 - 15 mins before you do this or you could get an air bag in the face.
HTH.
Old May 8, 2005 | 07:48 PM
matty872's Avatar
matty872
Sorry but my car aint got seatbelt pretensioners only a drivers airbag, Any other ideas the light has gone off again but give it couple of days it will be back on.
Old May 10, 2005 | 08:06 PM
richm's Avatar
richm
i agree with onion - code four is seatbelt pretensioners.. have a look under both seats anyway, for yellow connectors. Most four code problems are attributable to pretensioner connections.
Old May 11, 2005 | 08:30 PM
matty872's Avatar
matty872
sorry there is no wireing going anywhere near the seats my missus has a gti with them on so i have seen where the cables would run. any other ideas other than sell the car before it comes back on.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
mrice0107
Aug 21, 2015 07:55 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
