Escort Cosworth Fuel Pump.
Old May 3, 2005 | 10:02 AM
Lillford 500's Avatar
Lillford 500
Default Escort Cosworth Fuel Pump.
Can someone help me with a little problem?
When you turn the ignition on, you can hear the fuel pump charge the system then stop. Then obviously the fuel pump starts again once the engine fires up.
I need to find out what is controlling the pump and if it's a relay, which one is it?
One other thing, Is the fuel pump cut off switch in the N/S/F footwell behind the sill trim?
Anthony.
Old May 3, 2005 | 05:12 PM
Cossie-Iain's Avatar
Cossie-Iain
Fuel pump relay in the fuse box under your steering wheel.Its a great big tall yellow one I think.Yes fuel cut off where you said it was.
Old May 3, 2005 | 05:14 PM
Dave Henshall's Avatar
Dave Henshall
no, the fuel pump relay is a small brown one behind the large yellow one.
Old May 3, 2005 | 09:27 PM
Cossie-Iain
I was damn close
Old May 4, 2005 | 10:48 AM
sailorbob's Avatar
sailorbob
Default Re: Escort Cosworth Fuel Pump.
ECU cuts fuel pump if the engine isn't cranking, its a safety thing to kill the fuel pump in case of an engine stall after an accident.
Yes, just behind where the cill meets the A pillar.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
