Uprated brakes FRST on a budget any suggestions???????????
as above
was thinking esc cos,been told they are a bitch to fit & get set up + standard master cylinder ain't up to job
other options
focus St170
Jag x Type
aftermarket kits
willwood super lights???
not sure what option to take need some advise
cheeRS guys & girls
other options
focus St170
Jag x Type
aftermarket kits
cheeRS guys & girls
cossie calipers fit straight on need 5-10mm nuts to space the calipers out and elongated m10 bolts 30-35mm to hold calipers on performance ford feb 2003 page 60
Get some Willwoods! got them on my FRST, there's no feel to them but once you get the hang of them there AWESOME!!! There's a bypass where I live with a huge bridge and a round about at each end, I regularly scare the crap out of my mates by comin off and down the bridge at a ton 20 and leavin it till I'm about 100 meters from the roundabout till I brake!
You can feel the back off the car tryin to lift itself off the floor even with a passenger in the back! They squeel a bit when your just drivin normally but you soon forgive that when you can out brake all of your mates cars!!!
