2wd saph piston slap
Old Apr 27, 2005 | 09:08 AM
wimble's Avatar
wimble
Default 2wd saph piston slap
my saph suffers with piston slap do i need a re build if so whot pistons do i use the engins done 73.000 miles
Old Apr 27, 2005 | 01:32 PM
cossied's Avatar
cossied
Default slap
does it only slap when cold as they all do. the 4wd had an offset gudgeon pin that reduced the slap quite a bit. these pistons are lower compression depends on the depth of the head ie has it been skimmed. PJ motorsport can advise you.
Old Apr 27, 2005 | 04:10 PM
wimble's Avatar
wimble
it only slaps from cold so is this nothing to worie about cherss
Rsmat
89
Oct 12, 2015 07:50 AM
mark r
Sep 29, 2015 07:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
timsrs
22
Sep 24, 2015 08:14 PM
dojj
28
Sep 11, 2015 10:00 PM
