Smokin' & Leakin'
Old May 28, 2004 | 01:46 PM
SortedCossie's Avatar
SortedCossie
Default Smokin' & Leakin'
I have a 4x4 sapphire that keeps blowing the dipstick out, leaking oil onto the clutch and pushing oil up into the distributor. The engine has been completely rebuilt 3000 miles ago including rebore (using torque plate), new pistons & rings, refurbished head with new stem seals & bronze valve guides, everything lightened & balenced, grp A head set ect. The car has a group A breather system which has been cleaned out and checked for blockages. The only item on the engine that wasn't striped was the turbo, which is a hybrid T34. Is it possible that the turbo is pressurising the sump in some way as it only happens under load/boost?. Any one had the same problem and have a fix for this? It also smokes very slightly on the over run at high revs but don't they all do this? Current oil is a 0w/50 compared to the 10/40 we were using - this has cured some of the problem but not completely.
I'm beginning to suspect a damaged valve stem seal but don't fancy taking the head off again.
Old May 29, 2004 | 02:04 PM
ripper's Avatar
ripper
its broke m8
Si B
Alloy wheels and ICE for sale
Jun 21, 2012 04:33 PM
carlo
67
Nov 11, 2011 09:37 PM
drsrst2zvh
112
Jan 20, 2011 02:31 PM
jessie_rs
Jan 22, 2008 11:27 AM
deleted
15
Jul 21, 2006 03:17 PM
