Throttle Body question.
Old May 26, 2004 | 04:30 PM
Tanker3000's Avatar
Tanker3000
Default Throttle Body question.
Does any one know what size the cosworth throttle body is? im trying to build a new inlet system for my XR2i. The guy who set my engine up said the standard unit was restricting my power level, so told me to look into building a log type unit similar to the trust electrical kit for the zetec. The problem is i cant just switch to mulit bodys because my head has injector cutouts and iv spent a fortune having it modded, i also want to keep my uni-chip. So i was going to use the lower half of the efi inlet with the injectors then making a coustom plenum with maybee a cosssy TB. Any suggestions?
Old Jun 16, 2004 | 09:54 AM
AustenW's Avatar
AustenW
Cossy throttle body is 64mm OD and has a 58mm butterfly
Old Jun 16, 2004 | 11:53 AM
MadMac's Avatar
MadMac
Running 75mm Mustang one on my ZT
Gonna lean like a mo fo unless I get big enough injectors and a high enough pressure fuel pump
MadMac's Avatar
MadMac
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
