S2 Cab Turbo running problem
Old May 25, 2004 | 07:33 AM
CossieRob's Avatar
CossieRob
Default S2 Cab Turbo running problem
The car is an RS turbo converted Mk4 Cabrio and the main problem is that the car won’t drive!
The car was standing for about three months before my mate bought it, the old battery was charged up and the car fired up straight away, oil and water levels were fine. He drove the car around all Saturday afternoon as you do, but decided to go to Halfords and buy a new battery for it. He put the new battery on drove it again for a short while, when it started to splutter and run like a complete bag o shite! I did a compression test and everything was fine, changed the leads and plugs, fired it up and it idles no problem. When you try and drive it though it splutters and stalls! Anyone got any ideas? Could it be the coil because I know he moved it when he changed the battery (it had been relocated near the battery when it was converted from XR3I) Help!
Old May 30, 2004 | 11:09 PM
joe GSM's Avatar
joe GSM
before u changed the batery u must of jump started it with a flat battery this sometimes sends a power serge to the fuel computer which makes it run like bitch try another one its located in a black box nexst to the ecu
Old Jun 2, 2004 | 04:59 PM
davidnormanuk's Avatar
davidnormanuk
I had this problem. I found that the rubber cover on the connections for the coil was slightly off and arking to the centre of it causing the spark to be erattic.
Dave
big_Rad
Sep 15, 2017 09:36 AM
carlo
24
Oct 5, 2015 08:20 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
slammedorion
21
Aug 6, 2015 11:38 AM
