Fiesta 1.3 to sportka 1.6 engine swap
Hello, as the title says I want to swap my boring 69 hrsprs 1.3 rocam engine that comes in my 04 fiesta with the 1.6 rocam from a sportka/streetka wich makes a whaping 95 hrsprs, and i need some advice regarding the folowing.
I know that :
I know that :
- they are the sane engine, just diffrent bore size
- one uses a diffrent type of injectors and I might think fuel pump
- bothe use iac valve and a DBW throtthe body
- Can I just swap the engines without changing to the 1.6 ecu ?
- If i swap the ecu, wich looks the same as my ecu, will i retain all the functions that my car had before ?
- Can i use the gearbox from the 1.6 ?
- If i use the gearbox what axles do i need ?
