Charging system service now
Old Mar 30, 2021 | 11:04 AM
Ydda2's Avatar
Ydda2
Default Charging system service now
Hi the above has come up on my dashboard with battery light on I have a 2017 Ford Edge new battery fitted 6 months ago set up on forscan to correct battery settings but charging system service now has come on dashboard with battery light on battery still reads 13.7 volts with engine running and 12. 7 stopped any ideas to what is wrong
Old Mar 30, 2021 | 09:51 PM
GVK.'s Avatar
GVK.
If you have forscan, have you scanned the car???
Old Mar 31, 2021 | 06:52 AM
oldford's Avatar
oldford
Smart-charge systen not working. Alternator is in the 'dumb' mode and only gives 13.7 or 13.8 volts.
Did you use the prescribed battery type when replacing the battery?
Old Mar 31, 2021 | 08:46 AM
Ydda2's Avatar
Ydda2
Yes it is the correct battery type and it has been working okay for 6 months only started after connecting trailer lights
Old Mar 31, 2021 | 08:52 AM
Ydda2's Avatar
Ydda2
I have forscan but I am cautious about using it as frightened to cock it up when I fitted battery I updated it to new battery and for 6 months it’s been okay only started when I connected trailer lights says something like battery error and something about steering module in sccm module I will connect it again and see what it says can not find ware I updated battery now
saph4be
Oct 27, 2013 04:07 PM
chainsaw
Jun 17, 2009 10:10 PM
RSGUESTY
Oct 21, 2008 09:30 PM
robj20
Sep 10, 2008 07:08 PM
Ilovemyfez
Mar 30, 2005 02:41 PM
