Correct Battery Voltage
Old Mar 30, 2005 | 09:39 AM
Ilovemyfez's Avatar
Ilovemyfez
Default Correct Battery Voltage
Hello,
My car battery (lucas 12V, new) seems to sit at ~12V or below, whereas every other car battery sits at 12.5 - 12.8V. The haynes says 124+ = good charge, anything below needs charging.
I'm trying to figure out why it doesn't keep charge, as its a new battery! The alternator works as it shoots up to 14V when the engine's on!
Should i clean the battery earth/ground connections or something?
Any advice appreciated as i dont want another battery dieing!
thanks
Old Mar 30, 2005 | 12:30 PM
Ilovemyfez's Avatar
Ilovemyfez
ive disconnected the -ve from the car and the battery maintains it's voltage.. as soon as i connect it to the car, it starts to drop!!
checked all the earths i can find, seem ok ....
Old Mar 30, 2005 | 02:41 PM
Ilovemyfez's Avatar
Ilovemyfez
seems as if it is my neon/cold cathodes in the footwells drawing lots from the battery
Brickhouse
14
Oct 3, 2015 07:28 PM
