Transit connect rear shock removal
Old Mar 19, 2020 | 10:25 AM
scottp3000's Avatar
scottp3000
Default Transit connect rear shock removal
Hi,
Wonder if someone can help please?
Have a 2008 transit connect that's been lowered and fitted with Gaz shocks on the rear - one of them has gone pop
I'm trying to remove the lower shock bolt, but it seems too long and catches the u-bracket for the rear beam. Do I need to drop the rear beam to release the lower shock bolt? or is there a knack to it i'm missing?
Thanks in advance!
Scott
Old Mar 23, 2020 | 05:20 AM
iansoutham's Avatar
iansoutham
OCD Victim
If anything like my Golf, you undo the top bolt first to lower the whole unit which allows you to remove the lower bolt
jfallon94
Ford Range
Apr 5, 2014 11:00 PM
Oranoco
Apr 6, 2012 08:04 AM
andy130
Aug 7, 2011 10:47 PM
polly_x
Feb 15, 2008 04:41 AM
