Buzzing from relay when lights are on
Old 07-01-2012, 09:53 AM
Fordmad!
Fordmad!'s Avatar
Default Buzzing from relay when lights are on
When i turn my lights on the engine cuts out.
Theres a few relays under the dash by the pedals. Theres a blue relay that buzzes when lights are on. So i changed the relay and it still does it. Does it mean its shorting or that the relay holder is faulty
How can i see whats causing the problem?
Cars an xr3i efi
Old 07-01-2012, 10:14 AM
RS500/364
RS500/364's Avatar
if you take the relay apart the electric connection might just need a clean to connect better soloniod normal gets noise on some
Old 07-01-2012, 10:24 AM
Fordmad!
Fordmad!'s Avatar
Ive tried another relay but still does it.
Took them both apart and they look really clean and nothing looks out of place.
I think it could be the holder but im not sure.
When relay isnt in theres no noise when ignition is on with the lights on.
When its buzzing i can feel the relay vibrating aswell. How can i check if the relays are faulty?
Old 07-01-2012, 12:26 PM
Fordmad!
Fordmad!'s Avatar
Thought that the buzzing is caused from a faulty earth.
So i earthed a piece of wire and turned ignition and lights on and put the earthed bit of wire into the earth connection on the blue relay and the buzzing stops which suggests its a poor earth somewhere?
Have redone some of the earths in the bay but still no luck.
Is there anyway i can test the earths to see if there okay and working?
Is there anything else i can try? Really struggling now
Old 07-01-2012, 12:35 PM
7sean7m7
7sean7m7's Avatar
You can test the relay with a 9v battery across 2 of the terminals. Or just bridge the relay across the 2 thicker terminals with a paperclip or whatever o just make sure the relay isnt the problem.
Old 07-01-2012, 01:03 PM
Fordmad!
Fordmad!'s Avatar
I don't think the relay is the problem tbh but i will test both relays just to be sure. Im definatly thinking its a earth problem somwhere!
Old 09-01-2012, 05:15 PM
Glyn Mason
One Mad RS Nut
Glyn Mason's Avatar
hi Ive had some experience with this.
its like what was said before a bad earth or the connections to your head lamps on both sides are bad and need cleaning or connections need refreshing if the loom is old the wiring i have found tends to break quite easily the earths at both ends would be best made fresh and keep them separate from other earths connected to the same place make a fresh connection
hope this helps
Old 09-01-2012, 05:24 PM
Fordmad!
Fordmad!'s Avatar
I noticed that the earths are brittle and do snap reasonably easy as i have had to replace some.
So are you suggesting i just put new connections on all the earths ie the headlights?
Old 09-01-2012, 05:31 PM
Glyn Mason
One Mad RS Nut
Glyn Mason's Avatar
hi
yes i would think that would help did it on my escort rst had too use connector blocks and went back a good few inch's where loom is coverd put new or some better connectors on thats the main problem bad earths and wire breaking down it don't help on an old car when loom starts to break
hope this helps
Old 09-01-2012, 05:52 PM
Fordmad!
Fordmad!'s Avatar
Soon as i get a free day and good weather i will do all my earths and renew the thin old ones and clean up the connections and see if that helps!
RS500/364
RS500/364's Avatar
Originally Posted by Glyn Mason
hi
hope this helps
Just get some new crimps for the holder or new holder rewire
Old 09-01-2012, 05:56 PM
Fordmad!
Fordmad!'s Avatar
Yeah i was just going to replace the ends tbh just take the wire back an inch or so!
Old 10-07-2018, 06:25 PM
Bigcat40d
Bigcat40d's Avatar
Hi, My S1 has a missing BLUE RELAY.
Is this relay for head lamps?
I can not find any information about this relay in GOOGLE.
Please tell me the part number of this BLUE REPLAY.
Best Regards
Tony
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
stevecfrst1
30-09-2015 05:18 AM
deathrider666
28-09-2015 06:12 PM
28-09-2015 10:05 AM
Quick Reply: Buzzing from relay when lights are on
