Dry ICE to remove Dynamat
Old Feb 5, 2018 | 11:53 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
Default Dry ICE to remove Dynamat
Anyone had any experience with dry ice or the removal of dynamat? I have some that really does not want to come off and quite a lot of it, I saw some posts on other forums suggesting that you can drop the dry ice on, wait for the dynamat to crack and then pull it off.
If not I will stick with a heat gun and pallet knife
Old Feb 5, 2018 | 03:19 PM
smiley's Avatar
smiley
I'd try dry ice just for the crack good luck mate
Old Feb 5, 2018 | 04:48 PM
focusv8's Avatar
focusv8
NO, NO, it's not for Your Crack..
I've used dry ice to fit liners into a tractor engine.
I'd imagine the Dynamat shatters when it's iced.
Old Feb 5, 2018 | 06:06 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I tried a can of plumbers pipe freeze today as an experiment, it goes to minus 50 in 5 mins and the dynamat just broke up BUT it used a Ł22 can to do 1 sq ft. I like the idea of dry ice but will try a heat gun and a pallet knife before I go down that route....I can see fingers breaking off with my medical error history
Old Feb 5, 2018 | 09:32 PM
RichieST's Avatar
RichieST
Dry ice is great stuff, we used it loads at my old job. Usually for cocking about with though, we made bombs, froze and shattered loads of different stuff.
Old Feb 6, 2018 | 07:53 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
I take it you have to be careful not to come in to contact with it?
Old Feb 6, 2018 | 02:09 PM
nixon_2wd's Avatar
nixon_2wd
A friend of mine used dry ice to remove the stock sound deadening stuff. Worked really well.
Old Feb 6, 2018 | 06:41 PM
RichieST's Avatar
RichieST
Yes you had to be very careful. If you touch it for a second or two it will do no harm but any longer than that and you will get a frost burn. We handled it with welding gloves, they weren't made for it but were better than the gloves that were designed for the job!
Old Feb 6, 2018 | 06:42 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Will have a go on Friday with the heat gun but if I get fed up I will try the dry ice
Old Feb 6, 2018 | 06:43 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
This will be me
Oops
Old Feb 6, 2018 | 08:31 PM
smiley's Avatar
smiley
Old Feb 6, 2018 | 08:34 PM
costina's Avatar
costina
Live long and prosper!!
Dynamat is some sticky shit. I have installed loads of it but never taken it out.
Old Feb 7, 2018 | 08:11 AM
bassboy's Avatar
bassboy
Removing it in cold weather is best...once you have managed to peel a corner up, you will be surprised how easy it is to take off...may rip a few times though but it will come off easier when its cold
Alternatively, you can warm it up significantly so the bitumen is very soft and it will pull away easy...will need to wear gloves and may have to remove some bitumen with a flat blade etc (this is avoided if you take it off when it is cold)
Old Feb 7, 2018 | 12:14 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I can pull this with both hands and it hardly moves, some bits are great but others are a pain....I am finding the heat gun and knife / chisel works but it then sticks to your gloves and rips them
Old Feb 7, 2018 | 12:37 PM
RichieST's Avatar
RichieST
Get some old co2 fire extinguishers and give the stuck bits a good blast!
Old Feb 7, 2018 | 05:01 PM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
www.ddblasting.co.uk
Our service removes everything mate
Old Feb 7, 2018 | 05:10 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I did wonder about this, 1) what might it cost 2) would it make a mess 3) I assume it must be done outside 4)how do you stop it ruining the paint at the edges...like the sills?
Old Feb 7, 2018 | 06:47 PM
Ridgey's Avatar
Ridgey
Big bag of frozen peas on it......
Old Feb 7, 2018 | 08:44 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Its Dynamat, not your hardon
Old Feb 8, 2018 | 05:32 PM
Ridgey's Avatar
Ridgey
Old Feb 9, 2018 | 03:04 PM
stu20004x4's Avatar
stu20004x4
I would need a postcode and more details of the vehicle, preferably pics as well mate, can whatsapp them to me at 07811430278 or email info@ddblasting.co.uk
no messier than using a pressure washer. 99% of debris drops to the ground along with the media we use.
better off outside yes, everything around the target gets wet
our system is very precise, we can blast to within one cm of anything without causing any damage
Old Feb 9, 2018 | 06:51 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Thanks for the response, I have got the most of it out with vibration saw today but I am considering having the underside stripped so it can be painted. I will let you know. Thanks for the full reply.
Old Feb 17, 2018 | 04:52 PM
stu20004x4's Avatar
stu20004x4
No probs matey
gingeRS
Jun 28, 2012 05:23 PM
alexno1dj
Feb 12, 2012 07:57 PM
-beefy-
Oct 12, 2011 07:16 PM
Martin-Hadland
11
Nov 4, 2009 10:00 PM
Fudgey
17
Nov 2, 2005 12:28 PM
