XR3i Cab Thurst
Old May 17, 2004 | 10:11 AM
Paul_GTT's Avatar
Paul_GTT
Default XR3i Cab Thurst
My XR3i cab is finally running pretty well after a water pump and a head gasket.
However its drinking petrol like its a V8. Any obvious things to check and which way is leaner on the metering head adjustment?
Cheers!
Old May 22, 2004 | 08:09 AM
Lee @ Fusion's Avatar
Lee @ Fusion
whats it like on hot or cold start ??
Maybe the injectorsa are a bit tired and sticking open .
C/O adjustment on the metering head i think is anticlockwise to lean off .
Their is also a fuel pressure actuator , little black box on the meter head side ,
This does have an adjustable internal screw that u an use to richen up the mix but doubt if this would be the fault .
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
