Failed fuel pump??
Old Jul 19, 2016 | 07:08 PM
mrbox's Avatar
mrbox
Default Failed fuel pump??
Hi guys I picked a mk6 escort up the other day as a non runner
Problem:
the car turns over and fires very briefly before dying (regardless of throttle no throttle)
Things I have checked:
fuel pump fuse ok
relay ok
fuel shut of button is fully depressed
anything I have missed? I cannot hear the pump fire up when the ignition is turned on( which is what I suspect is the problem!).
thanks in advance
Mike
Old Jul 19, 2016 | 07:22 PM
london_chris's Avatar
london_chris
led by the clock? whats it doing?
Old Jul 19, 2016 | 07:25 PM
mrbox's Avatar
mrbox
steady on with ignition on. flashing whilst cranking
Old Jul 19, 2016 | 07:49 PM
martysmartie's Avatar
martysmartie
That means the immobiliser has an issue, most likely the key you are using is not coded correctly.
Martin
Old Jul 19, 2016 | 07:57 PM
mrbox's Avatar
mrbox
Martin
is the red key used for coding further keys? or does it deploy the missiles and oil slick
Old Jul 19, 2016 | 08:34 PM
martysmartie
You will have to let me know haha, but yes you need the master (red) key, as you suggested.
Martin
Old Jul 19, 2016 | 09:44 PM
RichieST's Avatar
RichieST
Count how many times the light flashes when cranking as this will give you a fault code. I always thought though that if the immobiliser wasn't deactivated, the car wouldn't even turn over.
Old Jul 21, 2016 | 11:00 PM
martysmartie
Depends on the immobiliser, i.e. how many points of immobilisation. I think PATS does fuel and ignition, hence it will still turn over.
Martin
Old Jul 22, 2016 | 10:57 AM
mrbox's Avatar
mrbox
working my way through this slowly! currently waiting for my next day off.
thanks for the help so far.
using the red key the red LED goes out when cranking.
no 12v feed to the fuel pump (orange/violet wire) but there is power to both circuits of the fuel pump relay and It is switching.
is the rollover switch wired before the relay or after?
other than that a broken wire or?? I'm stumped!!
Mike
Old Jul 22, 2016 | 11:51 AM
london_chris
inertia switch maybe in the passenger kick trim panel, may be tripped and killing the pump.
starts runs and dies is usually the immobiliser kicking out.
if the light by the clock is now going out when cranking hopefully the immob is switching off as it should.
try giving the fuel pump a fused temporary live supply to eliminate a broken wire from the inertia switch to the pump.
if the inertia switch is ok and in the reset position (i.e not tripped) and you can make it run from the temporary wire then i would be looking at fuel pump fuses and associated wiring.
Old Aug 6, 2016 | 08:01 PM
mrbox's Avatar
mrbox
just an update the car is now running again the fuel pump was dead. thanks again for the help folks much appreciated!
Old Aug 12, 2016 | 06:38 AM
3.0i_Sierra_RS's Avatar
3.0i_Sierra_RS
LOL!
cutch
May 2, 2016 05:55 PM
3dr cossie
Mar 7, 2016 05:23 AM
kevin micallef
Mar 6, 2016 05:36 PM
Rs(555)
Feb 28, 2016 08:31 PM
Jan 3, 2004 01:58 PM
